  2. Allegro X Capture CIS
  3. Capture reference designators swap
  • Subscribers 51
  • Views 16315
Lock2002
Lock2002 over 6 years ago
I have a preliminary component placement that I'm pretty far along with when an engineer decided to change all reference designators on the schematic. I'm not sure if they made other net or comp value changes before doing this. How should I go about fixing this?
  • excellon1
    0 excellon1 over 6 years ago
    Hi Lock.
    First thing, save your existing placed board under a different name so you have a backup.
    In capture use that new board name for both the input & output board.
    Generate netlist with the options "Place Changed components if same"  & do not open board file.
    Load your board in Orcad/Allegro.
    See if that works, believe it should.
    Another way to do it is from in Orcad/Allegro. Use import logic ! to pull in your new netlist.
    All the best.
  • Lock2002
    0 Lock2002 over 6 years ago in reply to excellon1
    This doesn't resolve the problem. All of the parts are placed.
  • excellon1
    0 excellon1 over 6 years ago in reply to Lock2002
    Well, I have a placed board and changed all the reference dez in capture and upon netlisting it did indeed update the board to the new references as described above. If I changed a footprint specific to one of the symbols that did not exist on the board "New Footprint", again netlisting worked fine and the board updated. The changed footprint is was under place component and the prior footprint was removed from the board.
    Doing a import logic from within the pcb editor also updated the placed board too.
    Everything works from here, not too sure what your trouble is there. What are you finding that's not working ?
  • Lock2002
    I'm finding that it's ripping most of the parts off the board.  Allegro places by reference designator as far as I know. Not sure how this works for you. When you renumber in Capture are using "Tools, Annotate"? The individual that renumbered did this, but set everything to "?" first and then renumbered.
    Can anyone else confirm that this works for them? I've tried it several times.
  • Lock2002
    0 Lock2002 over 6 years ago in reply to Lock2002
    Another thing to add. We aren't using a shared directory. I took a copy from their working directory.
