  2. Allegro X Capture CIS
  3. Capture Canvas Image (Allegro 17.4HF007) broken?
  • Replies 10
  • Subscribers 53
  • Views 17568
redwire
redwire over 6 years ago
Hi
I'm trying to see one you all out there can try to reproduce this issue I am seeing in Allegro.  17.4 HotFix 007,
Open a design, select "capture canvas image" and it should prompt you to save a bitmap image.  My bitmap is junk.  All white.
Anyone else? Cadence says it is working fine.
redwire
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    It is working fine..I didn't get such an issue...Check by installing s008....FYI software running on win7
  • DavidJHutchins
    0 DavidJHutchins over 6 years ago in reply to redwire
    Win7, Win8 & Win8.1 are not supported with 17.4, Windows 10 (64-bit) Professional the recommended upgrade path
  • digital1
    0 digital1 over 6 years ago in reply to DavidJHutchins
    Im running 17.4 on win 8.1 with no problems
  • DavidJHutchins
    0 DavidJHutchins over 6 years ago in reply to digital1
    I just downloaded HF008 & installed it on my Win8 laptop, 'capture image' now works correctly, however the infinite & octal cursors no longer work...
  • redwire
    0 redwire over 6 years ago in reply to DavidJHutchins
    I had infinite on and when I first started Allegro after HF008 install the cursors were broken.  I got out of Allegro, restarted and they started working again.  Would like to see if you have the same issue.  I have a feeling there is a bug lurking there...
  • DavidJHutchins
    I installed HF008 on my win10 laptop & found no issues ( other than the relentless MicroSlop patch installs ),
    went back to my win8.1  laptop & rebooted, now the infinite & octal cursors now work correctly...
