  2. Allegro X Capture CIS
  3. Capture Canvas Image (Allegro 17.4HF007) broken?
  • Replies 10
  • Subscribers 53
  • Views 17567
redwire
redwire over 6 years ago
Hi
I'm trying to see one you all out there can try to reproduce this issue I am seeing in Allegro.  17.4 HotFix 007,
Open a design, select "capture canvas image" and it should prompt you to save a bitmap image.  My bitmap is junk.  All white.
Anyone else? Cadence says it is working fine.
redwire
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    It is working fine..I didn't get such an issue...Check by installing s008....FYI software running on win7
  • DavidJHutchins
    0 DavidJHutchins over 6 years ago
    I had the same problem when I first loaded 17.4 on my Win8.1 laptop ( which isn't supported... )
    After I loaded 17.4 on my Win10 laptop the issue went away
  • redwire
    0 redwire over 6 years ago in reply to DavidJHutchins
    Hmmm...this is a Win7 machine...
  • excellon1
    0 excellon1 over 6 years ago
    On this, there is another way that I actually prefer to do screen captures that may help.
    Try use the print screen key on your keyboard to capture the image on a "Windows Machine",  open your graphics application and click paste, the allegro pcb will be faithfully reproduced.
    At that point you could save it out in any of the supported formats your graphics app supports.
    The standard windows paint program works good for this too as you can do things like crop or add notes to the picture.
    All the best.
  • AvengerThanos
    0 AvengerThanos over 6 years ago
  • redwire
    0 redwire over 6 years ago in reply to AvengerThanos
    Yea!  That fixed it!  Support can not figure out what's wrong.
    Update:  Support has mentioned now that there is a known bug in HF007 that causes blank output when running openGL.  HF008 corrects this.
