  2. Allegro X Capture CIS
  3. CIS - Multiple symbols per library or single symbol per...
  • Replies 13
  • Subscribers 52
  • Views 11887
CIS - Multiple symbols per library or single symbol per library
thomasli
thomasli over 6 years ago
I admit, I do have an Altium background but I'm trying to figure out how CIS exactly works. I figured that it is very similar to Altium's DbLib feature, in fact, they seems pretty much the same.
I'd like to know what the preferred way to handle schematic symbols is. I have seen that for Allegro PCB it is one footprint per file with the footprint name being the filename without the dra extension. This is also how we did it with Altium. For schematic symbols, I have seen that basically all symbols are stored in a single library file (or some number between 1 and 10) but not one symbol per library file (olb). Back then, we kept one symbol per file to nicely integrate with version control systems. It was always possible to determine when a symbol had been changed (and if).
I am not quite sure yet, how schematic libraries are being found. I found a reference to [Part Library Directories] which contains the location of our 3 library files. Does Orcad browse these libraries? How does that perform for .. say .. 1000 files with one symbol each?
If that is unfeasible, is there another way how to best integrate libraries into a version control system?
  • AvengerThanos
    0 AvengerThanos over 6 years ago
    Well, it works in a way how they are defined in the database. You can use 1000 symbols in one lib file / 1 symbol per lib file.
  • thomasli
    0 thomasli over 6 years ago in reply to AvengerThanos
    As far as I understand, the number of libraries is somewhat unlimited but the main question should be if there is a performance hit involved in having multiple files? From the standpoint of version control the 1 symbol / file strategy would be far better
  • RFinley
    0 RFinley over 6 years ago in reply to thomasli
    Manglement pushes me to "keep it simple" with three libraries covering more than 5 thousand MPNs.
    I'm in hell.
    Subdividing your libraries saves aggravation.   Even if you have OLB files for passives, mounting/mechanical, op-amps, vregs, and memory/CPUs.
    Symbol libraries are only accessed when CIS is launched (if you have seen the massive libraries that are included, it's just not a problem.)
  • drobny
    0 drobny over 5 years ago
    Put the full path to the symbol in the database..
  • thomasli
    0 thomasli over 5 years ago in reply to RFinley
    Thank you for the insight.
