  2. Allegro X Capture CIS
  3. CIS - Multiple symbols per library or single symbol per...
  • Replies 13
  • Subscribers 52
  • Views 11888
CIS - Multiple symbols per library or single symbol per library
thomasli
thomasli over 6 years ago
I admit, I do have an Altium background but I'm trying to figure out how CIS exactly works. I figured that it is very similar to Altium's DbLib feature, in fact, they seems pretty much the same.
I'd like to know what the preferred way to handle schematic symbols is. I have seen that for Allegro PCB it is one footprint per file with the footprint name being the filename without the dra extension. This is also how we did it with Altium. For schematic symbols, I have seen that basically all symbols are stored in a single library file (or some number between 1 and 10) but not one symbol per library file (olb). Back then, we kept one symbol per file to nicely integrate with version control systems. It was always possible to determine when a symbol had been changed (and if).
I am not quite sure yet, how schematic libraries are being found. I found a reference to [Part Library Directories] which contains the location of our 3 library files. Does Orcad browse these libraries? How does that perform for .. say .. 1000 files with one symbol each?
If that is unfeasible, is there another way how to best integrate libraries into a version control system?
  • thomasli
    0 thomasli over 5 years ago in reply to drobny
    Thank you for the insight. Can you give an example for that? What do you mean by "full path"?
  • drobny
    0 drobny over 5 years ago in reply to thomasli
    If you have several symbols with the same name in different libraries, Orcad will use the first found symbol.
    It is better to use the full path to the symbol in the database, Orcad will use it from that location.
    for exaple
    If you want to track changes in libraries and individual symbols, export the symbol from the library to xml.
    Then it is easier to see the changes. You can do this with the TCL and OLB2XML commands and vice versa XML2OLB.
  • thomasli
    Thanks, that is great help. The OLB2XML would have been my next question :-)
  • thomasli
    drobny: I've been trying to locate the OLB2XML and XML2OLB commands but was unable to find them. I was able to create an XML via the File -> Export menu option. Are you aware of a possibility to extract metadata (symbol name, default reference designator, ...) from an OLB file from the command line?
  • drobny
    Mea culpa! The right command is XMATIC_OLB2XML etc.  Method of the xmatic class.
    The command should be entered in the OrCada window  or selected from the File -> Export menu
    It is possible to run this command from the Windows command line, but not directly... If you want, I can write a console application for you..
