  2. Allegro X Capture CIS
  3. CIS - Multiple symbols per library or single symbol per...
  • Replies 13
  • Subscribers 52
  • Views 11894
CIS - Multiple symbols per library or single symbol per library
thomasli
thomasli over 6 years ago
I admit, I do have an Altium background but I'm trying to figure out how CIS exactly works. I figured that it is very similar to Altium's DbLib feature, in fact, they seems pretty much the same.
I'd like to know what the preferred way to handle schematic symbols is. I have seen that for Allegro PCB it is one footprint per file with the footprint name being the filename without the dra extension. This is also how we did it with Altium. For schematic symbols, I have seen that basically all symbols are stored in a single library file (or some number between 1 and 10) but not one symbol per library file (olb). Back then, we kept one symbol per file to nicely integrate with version control systems. It was always possible to determine when a symbol had been changed (and if).
I am not quite sure yet, how schematic libraries are being found. I found a reference to [Part Library Directories] which contains the location of our 3 library files. Does Orcad browse these libraries? How does that perform for .. say .. 1000 files with one symbol each?
If that is unfeasible, is there another way how to best integrate libraries into a version control system?
  • thomasli
    0 thomasli over 5 years ago in reply to drobny
    drobny Thank you for the offer which I happily accept. Is there some resource which outlines how to run arbitrary scripts from the command line somewhere? Do those need to be run through some tcl/tk interpreter?
  • drobny
    0 drobny over 5 years ago in reply to thomasli
    What version of a software you have installed - 17.4 or 16.6 ?
    Application Notes  -> c:\Cadence\SPB_17.4\tools\capture\tclscripts\OrCAD_Capture_TclTk_Extensions.pdf
  • thomasli
    I'm on 17.4.
    I think I may have used the wrong meaning of command line: What I meant was to run some kind of TCL interpreter/script from the DOS command line, without opening OrCad Capture. The idea is to read all library files and check if certain values are consistent. The further idea would be to run this automatically each night and then come up with a list of things which are not ok in the next morning. I'd like to get some structure into our libraries.
