  2. Allegro X Capture CIS
  3. Non activated "Place database Part" in OrCAD CIS 16.6
  • Subscribers 51
  • Views 3604
CK LEE
CK LEE over 5 years ago
Hi, I am a new user on OrCAD 16.6 CIS. I have connected CIS DB ( my team use it). I can open CIS Explorer and choose a part, BUT, I cannot place the part i selected on my Schematic.
Is there anyone how can help me? I put too much my energy now.
CK
  • RFinley
    0 RFinley over 5 years ago
    Think you have half of what you need:  the database source.
    Ask your coworkers for the official config file that references the DBC used to connect to the database.
    It tells Orcad where to load the symbol libraries (*.OLB) on launch that are used.  Without that, you will see the red lines.
    Should see two lines
    [Part Library Directories]
    Dir0=C:\library path of some sort
    The location for this config file is always obtained on launch.  >Window >Session Log   First line.
  • CK LEE
    0 CK LEE over 5 years ago in reply to RFinley
    Thanks , I will check it.
