  2. Allegro X Capture CIS
  3. Capture part name length more than 31 characters?
  • Subscribers 51
  • Views 16564
nickwallis
nickwallis over 5 years ago
Does anyone know if it is possible to increase the 31 character limit for part names in Capture? I am getting the following error whilst importing some library XML:
XMATIC : ERROR(ORDBDLL-1099): Illegal name length. Maximum name length is 31 characters
I can work around this but it would be better not to have this limitation.....
thanks
-Nick
  • oldmouldy
    0 oldmouldy over 5 years ago
    This looks like a "built in" limitation of the Name Length and there doesn't appear to be a setting that controls this.
  • nickwallis
    0 nickwallis over 5 years ago in reply to oldmouldy
    OK thanks for the quick reply.
  • AvengerThanos
    0 AvengerThanos over 5 years ago in reply to nickwallis
    You can change the limit to 255 max under Tools - create netlist - setup - change the min value 31 to 255 - Ok
  • nickwallis
    0 nickwallis over 5 years ago in reply to AvengerThanos
    Thanks, but that's not the same thing.
    My question was about the maximum length for the part name (that is, the "Name" field when you add a new part to an OLB) - like the below image.
    -Nick
  • AvengerThanos
    You will be permitted to have more than 31 characters, only if the above settings are done. I could type part name of 42 characters without any issue because of the settings done.
    Refer below images.
