  2. Allegro X Capture CIS
  3. How to export a ISCF (Intel Schematic Checking Format) file...
  • Replies 8
  • Subscribers 52
  • Views 9266
How to export a ISCF (Intel Schematic Checking Format) file from 17.2 Cadence/Allegro PCB Designer ?
mikentucson
mikentucson over 5 years ago
Is it possible to export a ISCF (Intel Schematic Checking Format) file from 17.2 Cadence/Allegro PCB Designer ?
Searching the internet I see demos with orcad capture, but this doesn't translate to 17.2 Cadence/Allegro.
Thanks for the help.
  • DavidJHutchins
    DavidJHutchins over 5 years ago +1
    It worked for me after specifying the -temp folder location, as shown below: C:\Temp\dsn\connorsville_fab_x_001_archive>geniscfnetlist Project file missing. Usage: geniscfnetlist -proj <project file…
  • DavidJHutchins
    0 DavidJHutchins over 5 years ago
    You can't generate the ISCF file from within Allegro, the only option is to output it from Capture ( which calls the geniscfnetlist program )
  • DavidJHutchins
    The Intel web site https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en
    states they will accept a ISCF or board file as input, so you can just send your board file
  • mikentucson
    0 mikentucson over 5 years ago in reply to DavidJHutchins
    Hi David.  Thank you for the reply.
    I can't figure out how to get my design into Capture.  I do see in Allegro PCB Designer, Tools -> Library Tools -> Export -> Design Entry HDL to Orcad Capture.
    It asks for a 'Library' and 'Cell'.  For library I select 'card_lib'.  For cell I select 'card'.  Hitting 'OK', the translation fails with a LCaptureConceptUI64 window indicating 'Encountered
    an improper argument.'.
    A new window labelled 'Select symbols' appears.  This looks like it wants me to select DesignEntryHDL symbols to export to a Capture library.
    Am I barking up the right tree?
    Thanks.
  • DavidJHutchins
    0 DavidJHutchins over 5 years ago in reply to mikentucson
    Wrong tree...
    That conversion tool only converts schematic symbols, Cadence doesn't supply anything to convert Concept to OrCad schematics
  • mikentucson
    It looks like in 17.4 you can generate an ISCF using geniscfnetlist.
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=concepthdl.xml&title=Allegro%20Design%20Entry%20HDL%20User%20Guide%20--%20Netlisting%20Your%20Design%20-%20Generating%20Netlist%20in%20ISCF%20format&hash=pgfId-1039725&c_version=17.4-2019&path=concepthdl/concepthdl17.4-2019/Netlisting.html#pgfId-1039725
    Installing 17.4, and trying that I get:
    Fatal error(s) found while reading Project file
    Please correct the error(s) and rerun the program
    Generate ISCF Netlist run on Jun 1 11:52:05 2021
      2 errors detected
    I can't find any output log describing the error.
