  2. Allegro X Capture CIS
  3. How to export a ISCF (Intel Schematic Checking Format) file...
  • Replies 8
  • Subscribers 52
  • Views 9267
How to export a ISCF (Intel Schematic Checking Format) file from 17.2 Cadence/Allegro PCB Designer ?
mikentucson
mikentucson over 5 years ago
Is it possible to export a ISCF (Intel Schematic Checking Format) file from 17.2 Cadence/Allegro PCB Designer ?
Searching the internet I see demos with orcad capture, but this doesn't translate to 17.2 Cadence/Allegro.
Thanks for the help.
  • DavidJHutchins
    DavidJHutchins over 5 years ago +1
    It worked for me after specifying the -temp folder location, as shown below: C:\Temp\dsn\connorsville_fab_x_001_archive>geniscfnetlist Project file missing. Usage: geniscfnetlist -proj <project file…
  • DavidJHutchins
    0 DavidJHutchins over 5 years ago
    Usage:
    geniscfnetlist -proj <project file name> -o <iscf file location> [-temp <log file location> -compprops <comma separated list of propnames>] [-pinprops <comma separated list of propnames>] [-groundnets <comma separated list of groundnetn
    C:\Temp\dsn\connorsville_fab_x_001_archive>geniscfnetlist -proj connorsville_fab_x_001.cpm -o connorsville_fab_x_001.txt
    Cannot open the list file 'geniscfnetlist.log' !!!
    C:\Temp\dsn\connorsville_fab_x_001_archive>md tmp
    C:\Temp\dsn\connorsville_fab_x_001_archive>geniscfnetlist -proj connorsville_fab_x_001.cpm -o connorsville_fab_x_001.txt -temp tmp
    Generate ISCF Netlist 17.4-2019 S014 (3914599) 1/24/2021
    Copyright 2011 Cadence Design Systems, Inc
    Reading File : C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstchip.dat(00:00:00.06)
    Reading File : C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxprt.dat(00:00:00.02)
    Reading File : C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxnet.dat(00:00:00.01)
    Reading File : C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstcmdb.dat(00:00:00.34)
    Writing Component section...
    Finished writing Component section.
    Writing Pins section...
    Finished writing Pins section.
    Writing E-Nets section...
    Finished writing E-Nets section.
    Writing Buses section...
    Finished writing Buses section.
    Writing Nets section...
    Finished writing Nets section.
    Writing Ground section...
    Finished writing Ground section.
    Writing Power section...
    Finished writing Power section.
    Generate ISCF Netlist run on Jun 1 13:51:30 2021
    DESIGN NAME : 'CONNORSVILLE_FAB_X_001'
    PACKAGING ON 01-Jun-2021 AT 09:52:52
    No error detected
    No oversight detected
    No warning detected
    cpu time 0:00:48
    elapsed time 0:00:00
    C:\Temp\dsn\connorsville_fab_x_001_archive>gvim connorsville_fab_x_001.txt
    C:\Temp\dsn\connorsville_fab_x_001_archive>type tmp\geniscfnetlist.log
    Starting to read C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstchip.dat
    Finished reading C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstchip.dat (00:00:00.06)
    Starting to read C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxprt.dat
    Finished reading C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxprt.dat (00:00:00.02)
    Starting to read C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxnet.dat
    Finished reading C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstxnet.dat (00:00:00.01)
    Starting to read C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstcmdb.dat
    Finished reading C:/Temp/dsn/connorsville_fab_x_001_archive/worklib/connorsville_fab_x_001/packaged/pstcmdb.dat (00:00:00.34)
    CROSS_REFERENCE OFF
    DIRECTORIES <none>
    FEEDBACK OFF
    LIBRARIES 'connorsville_fab_x_001_lib' 'standard' 'dev_fconn' 'dev_misc'
    'mstr_conn' 'mstr_digital' 'mstr_discrete' 'mstr_fconn'
    'mstr_memory' 'mstr_sconn' 'mstr_standard' 'mstr_symbols'
    'mstr_ttl' 'mstr_vreg' 'pae_devlib'
    MASTER_LIBRARIES <none>
    MAX_ERRORS 500
    OVERSIGHTS ON
    SINGLE_NODE_NETS ON
    SUPPRESS <none>
    WARNINGS ON
    No error detected
    No warning detected
    cpu time 0:00:48
  • mikentucson
    0 mikentucson over 5 years ago in reply to DavidJHutchins
    This worked on my 17.2!  Thank you David!
  • luvishis
    0 luvishis over 5 years ago in reply to DavidJHutchins
    Elgris Technologies (www.elgris.com) can translate Concept schematics to OrCAD and can translate OrCAD schematics to Concept
