  2. Allegro X Capture CIS
  3. Removing Additional Property Columns
  • Subscribers 51
  • Views 11729
Gelo M
Gelo M over 5 years ago
Currently using OrCAD Capture v17.2.
When I open component properties, I see an additional column colored in yellow:
Same with title blocks:
How do I remove or hide these additional columns in yellow?
Thanks.
  • steve
    steve over 5 years ago +1
    so this displays the instance (white column) and occurrence (yellow column) for the parts. You can click on the - symbol at the top of the white column to hide the yellow column. Occurrences are usually…
  • Gelo M
    Gelo M over 5 years ago in reply to steve +1
    Hi Steve, Much thanks for the info! I'm dealing with a flat schematic (no repeating blocks) and preferred to not see the property columns for occurrences so I invoked this:
  • steve
    0 steve over 5 years ago
    so this displays the instance (white column) and occurrence (yellow column) for the parts. You can click on the - symbol at the top of the white column to hide the yellow column. Occurrences are usually used if you have a complex hierarchy. There's an article here which may be of interest Understanding Instance and Occurrence Modes of Design Annotation (cadence.com)
  • Gelo M
    0 Gelo M over 5 years ago in reply to steve
    Hi Steve,
