  2. Allegro X Capture CIS
  3. Design Compare - A few clicks to review design changes
  • Subscribers 51
  • Views 10947
DesignTech
DesignTech over 4 years ago
Creating a PCB schematic design is an iterative process, and very often, you need to know the changes done in the newer version of the design. As a manager, you may want to review the changes, or even designers themselves may want to check for differences in the current revision versus the old version of the design.
 The Compare Design feature in OrCAD Capture is a powerful diff tool to compare two designs. The simple and intuitive user interface of this tool allows you to compare the designs and review the changes. The difference report is an HTML file which can be opened within the tool or independently in a web browser.
The difference report lists the following:
  1. Added or deleted parts, symbols, nets, etc.
  2. Part pin connectivity differences
  3. Property value changes on components/nets
  4. Flat net differences between the designs
  5. Changes in design itself like a new page/folder
Explore this handy utility under the Tools menu in Capture CIS.
Team DesignTech
Cadence Design Systems
  • AvengerThanos
    AvengerThanos over 4 years ago in reply to DesignTech +1
    That's great..!!! Thanks
  • hoshen83
    hoshen83 over 4 years ago
    Dear Team DesignTech,
    I saw your feature of Compare Designs, and I tried to make it automatic, so I can export an HTML with the design difference from the command line. I tried to do this with this function: OrHandlerDesignDifference::doCompareA found at OrHandlerDesignDifference.tcl file, and I also tried to just "record" my operations to the CAPTURELOG folder, but no xml file was created.
    Can you please tell me how to make this operation automatically?
    Thanks a lot!
  • AvengerThanos
    How to get the component-specific differences listed in table output. For instance, the 2 different designs have U1 with different part numbers. In the design compare output, U1 will be shown as difference but the reason for the difference isn't listed in difference table.
  • DesignTech
    DesignTech over 4 years ago in reply to AvengerThanos
    You can see property and connectivity differences of a component under All Differences report as shown below. Give it a try. If you still find any issue, please create a case on Cadence Learning and Support portal at http://support.cadence.com to get help from an AE.
    Regards
    Team DesignTech
  • hoshen83
    hoshen83 over 4 years ago in reply to hoshen83
    Is there a way to compare two designs from the command line without the user having to click on something?
  • DesignTech
    DesignTech over 4 years ago in reply to hoshen83
    The compare design functionality is only available through UI and a corresponding TCL command is not available for now.
    Regards
    Team DesignTech
