  2. Allegro X Capture CIS
  3. Text Now Rotates with Part
  • State Verified Answer
  • Subscribers 50
  • Views 9763
jgregoire
jgregoire over 4 years ago
Normally, when rotating a schematic part, text properties (Refdes, value, etc.) would remain in a fixed orientation. All of a sudden now when I rotate a part, the text properties rotate with it.
What happened?
  • DS1995
    DS1995 over 4 years ago +1 verified
    Check if the "Context based instance properties" is switched ON in the Options > Extended Preferences > Design and Libraries. You can keep this option ON once and check if the rotation is as per your need…
  • DS1995
    +1 DS1995 over 4 years ago
    You can keep this option ON once and check if the rotation is as per your need. If not, then try keeping this OFF and check if how text rotates.
  • jgregoire
    0 jgregoire over 4 years ago in reply to DS1995
    Turning that off did the trick! I must have toggled it by accident.
    So many options in OrCAD with meaningless names that do unexpected things...
