  2. Allegro X Capture CIS
  3. OrCAD - Tip of the Week: Using Zoom in OrCAD Capture
  • Subscribers 53
  • Views 7697
DesignTech
DesignTech over 4 years ago
While designing or reviewing a schematic, one of the most used functions is zoom-in and zoom-out. We might not even realize how much we use the zoom while working on our designs. Here is a quick tip on zooming in and out in a Capture design. Along with the zoom option in UI, you can use the following with ease:
  1. In Capture, zoom works just like Windows. You can use Ctrl + mouse scroll wheel to zoom in and out.
  1. Use the I and O keys to zoom in and zoom out, respectively.
The above operations will zoom the area centered around your mouse pointer.
Try this new trick and see if working on the design seemed a bit easier now!
Team DesignTech
Cadence Design Systems
  • Schulz Jordan
    Schulz Jordan over 4 years ago
    How do we set up custom hotkeys in capture like in PCB editor?
  • AyushD
    AyushD over 4 years ago in reply to Schulz Jordan
    capture does not support customizing hotkeys
  • CharlesLuies
    CharlesLuies over 4 years ago
    How do we create custom hotkeys in capture, similar to how we do in PCB editor? io games
  • DesignTech
    DesignTech over 4 years ago in reply to CharlesLuies
  • DG202504226528
    DG202504226528 8 months ago in reply to DesignTech
    Is Orcad ever going to be updated???? This tool is archaic to say the least.  It'd be great if all the tools actually had the same sort of way to zoom.  Like come on... Having similar things do similar things within the pcb or schematic tool should be easy and something done at defaut.
