  2. Allegro X Capture CIS
  3. NetGroup random behavior
  • Subscribers 51
  • Views 10681
Fredda
Fredda over 4 years ago
I'm struggling to connect signals to a NetGroup I've created. It feels like the behavior of Capture is totally random. This is what I do:
Right click a wire or a pin -> Connect to Bus -> Click on the NetGroup
All sorts of things seem to happen. Single click works sometimes, but you never know in what direction the Bus Entry will connect. Sometimes the net name is not added and sometimes it's just plain weird...
Things are more likely to go right if I right click on a pin than on a wire and then chose Connect to Bus. But what are the rules here? And what is the correct procedure to avoid things like above?
/F
  • Fredda
    0 Fredda over 4 years ago
    Ok, still struggling with this. Sometimes it works and sometimes it doesn't. And there's no obvious reason why it doesn't work sometimes.
    Capture Session Log says: ERROR(ORCAP-2171): Auto Connection Failed between ( 3.700000,3.300000 ) and (4.700000,3.300000 )
    Will it work if I do everything manually? That is, manually placing net aliases and place bus entries?
  • Fredda
    Here's an example of what can go wrong...
    Play this video
  • oldmouldy
    0 oldmouldy over 4 years ago in reply to Fredda
    Which exact version are you running? The auto-connections are expecting the grid to be 1:1 of the Pin Grid, it looks like you are using 1:2 which might also be related to the issue.
  • Fredda
    0 Fredda over 4 years ago in reply to oldmouldy
    Version is OrCAD Capture CIS 17.4-2019 S024 (3998392) [12/6/2021].
    Grid spacing is 1/2 of pin to pin. I'll change and see if it works better. Thanks.
