  2. Allegro X Capture CIS
  3. create a user form
  • Subscribers 51
  • Views 8765
create a user form
tennywhy
tennywhy over 4 years ago
Does anyone know how to create a form with a tcl script in orcad 16.6?
I tried it and always reported the error cant invoke toplevel.
In addition, during the test, it was found that the menu could not be opened by macro commands
Menu "Accessories::Cadence TclTx Utilities::Utilities"
Does anyone know how to open this menu with tcl? Much appreciated
  • tennywhy
    0 tennywhy over 4 years ago
    could anybody help me ?
  • soll
    0 soll over 4 years ago
    i could not help you to write a form using TCL (i honnestly don't know what that is), but did you considered using Skill and the "form language" ?
    This video by Cadence is useful to get a grasp of how it is done.
    This video by Robert Feranec goes much more in depths and is well explained.
    The Algroskill.pdf manual has a chapter concerning the form interface. It is quite obscure but there is useful info in it. You can find algroskill.pdf by going to your Cadence installation folder, then in the doc folder.
    Hope it helps
  • tennywhy
    0 tennywhy over 4 years ago in reply to soll
    Thank you very much for your reply soll, I didn't explain the previous question very clearly,
    In fact I can create the form, the problem I have is:
    When I run my tcl script directly, I get the error "Cannot invoke button command: application has been destroyed",
    But when I manually open the menu "Accessories::Cadence TclTx Utilities::Utilities" once, and then run my tcl script,
    everything works fine. I tried to open the "Accessories::Cadence TclTx Utilities::Utilities" menu first with tcl, but found
    This menu does not support opening with tcl scripts. I carefully checked the code corresponding to "Accessories::Cadence TclTx Utilities::Utilities" and did not find any corresponding clue.
    If I add "package require Tk" to my code, it will function normally, but there will be create an extra form for no reason, and it cannot be closed or the function will not work properly.
    I'm stuck at this step now, any advice is greatly appreciated
