  2. Allegro X Capture CIS
  3. Error exporting PDF OrCad Capture 17.4
  • Subscribers 51
  • Views 13165
Wall93
Wall93 over 4 years ago
Trying to exporting PDF of my schematic generated file is damaged, I can't open it.
Sometimes (randomly) I can open it, but bookmarks and properties are not present.
Here my PDF Export settings:
BR
  • rg13
    0 rg13 over 4 years ago
    Make sure that you are updated with some of the recent hotfixes of SPB version.
    Also, if this is design specific issue, please contact Cadence customer support with your archived design.
  • Wall93
    0 Wall93 over 4 years ago in reply to rg13
    Thank you fro your replay.
    Not sure if my hotfix are last ones....
    What's strange is that my colleagues have not same issue...
    I have PDF Export issue with all designs
  • rg13
    0 rg13 over 4 years ago in reply to Wall93
    Try to rename capture.ini at your end. See whether it helps or not.
    You can find its location in starting of session log window when you start any Capture session.
  • AyushD
    0 AyushD over 4 years ago in reply to Wall93
    you can check your hotfix by clicking on Help-> About Allegro Design Entry CIS...
  • Wall93
    Thank you
    I tried to rename Capture.ini but I don't see big improvements.
    Now exporting PDF I get this window:
    Then PDF is generated, but properties and bookmarks are not present.
    But as I saw it happens randomly, also without  Capture.ini renaming.
    That's my hotfix version:
    Thank you both
