  2. Allegro X Capture CIS
  3. broken character on the value
  • Subscribers 51
  • Views 7587
Fluteloop
Fluteloop over 4 years ago
My CM sents Orcad schematic.
but, it does not show properly as below.
But, it's not broken on his screen.
could you advise me what should i check?
  • rg13
    0 rg13 over 4 years ago
    There can be regional language setting difference at your and your colleagues end.
    I am not sure which language characters it is showing on schematic and in the Display properties dialog. However, you can check which regional language is set for non-unicode programs by following below steps:
    1. Close all the Cadence SPB applications.
    2. Open the Control Panel.
    3. Select Region.
    4. Select the Administrative tab.
    5. Check the language for non-Unicode programs.
    Also, If above does not help, you can try exporting and importing your design to EDIF 200 format to see if it removes these non desirable characters.
  • RFinley
    0 RFinley over 4 years ago
    I suspect there are Unicode/foreign characters in their CIS database.
    Haven't run across an option Orcad to do this on its own.
