  2. Allegro X Capture CIS
  3. Display/add net Classes in Schematic
  • State Verified Answer
  • Subscribers 52
  • Views 5364
FilipSwe
FilipSwe over 4 years ago
Hello!
Is there a way to see for example the spacing class on a net in the schematic without going into constraints manager? or add nets to a class?
So to explain a bit further:
Lets say I have made multi page schematic and I want to add physical spacing constrains to my nets. I can do this by going into constraint manager but it's a little inconvenient sometimes as most nets will have a long Nxxxx number and going back and forth between schematic and constraint manager to look which net is which is a bit slow. Of course I can make it easier by naming all my nets properly but I'm just wondering if there's an alternative I have missed.
You used to be able to set a property for a net that could be displayed, for example NET_SPACING_TYPE but it wont let me do that now since constraints manager is enabled for the schematic design.
It would also be great if I could hover or click on a net to see what classes it belongs to but I have not found an option for this.
Sorry if my questions are not clear.
Filip
  • SolderMonkey
    SolderMonkey over 4 years ago +1
    As far as I'm aware the ability to add properties to nets was binned many years ago in favour of Constraint Manager. I was a Concept user at the time, I assume the same was done for the OrCAD flow.
  • jc teyssier
    jc teyssier over 4 years ago in reply to SolderMonkey +1 verified
    Since 17.2 this is like this Last version to be able to handle NET_PHYSICAL_TYPE and NET_SPACING_TYPE (and i guesss NET_ELECTRICAL_TYPE) was 16.6 Big loss for me and a lot of colleagues. Workaround…
  • SolderMonkey
    0 SolderMonkey over 4 years ago
  • jc teyssier
    +1 jc teyssier over 4 years ago in reply to SolderMonkey
    Since 17.2 this is like this Disappointed
    Workaround: create a user propertyin schematic (say MY_NET_SPACING and MY_NET_PHYSICAL),and use it into allegro to assigne NET_SPACING NET_PHYSICAL.
    Or use the pretty unusable cronstrint manager (and Nxxx nets Disappointed)
  • FilipSwe
    0 FilipSwe over 4 years ago in reply to jc teyssier
    Thanks for your answer!
    I hadn't thought of that workaround. I agree, big loss.
