  2. Allegro X Capture CIS
  3. I don't see the Allegro PCB Design CIS L suite when opening...
  • Replies 11
  • Subscribers 53
  • Views 9671
I don't see the Allegro PCB Design CIS L suite when opening Orcad Capture
avant
avant over 4 years ago
When I try to open Capture, I don't see the Allegro PCB Design CIS L option. I cannot open Capture using this choice. The other suite options are always checked out.
We are using a server based license.
The software reseller has not solved our issue.
Here's what other users see as choices when opening Capture:
Here's what I see:
I cannot open Capture using the Allegro feature. I have to have someone else create netlist files for me.
We are using version 17.2 S070
Any help would be appreciated.
  • RFinley
    RFinley over 4 years ago
    I think that there is an Orcad version of CIS and an Allegro version of CIS.   Are you trying to launch and use the Orcad CIS app?
    I have Allegro PA-3100.  When I open CIS, I see Allegro 2022.
    (had to uninstall Orcad and install Allegro when I switched.)
  • avant
    avant over 4 years ago in reply to RFinley
    I may try that. All I see is "Capture CIS". don't know if it's Orcad or Allegro.
  • RFinley
    RFinley over 4 years ago in reply to avant
    Looks like you just need to install Allegro CIS from the installer (probably not the entire front end to layout suite.  Just Allegro CIS.)
    I personally use a VAR.  But, I work for a company having Virtuoso licenses.
    Cadence cannot sell/issue Orcad CIS licenses.  But, Cadence can issue Allegro CIS licenses to us.
  • avant
    Thanks! I'll give that a try.
  • jc teyssier
    jc teyssier over 4 years ago
    Looks like others and you do not use same license file. Or same socket ( 5280@lic_server or 5281@lic_server , something like this)
