  2. Allegro X Capture CIS
  3. What areas of OrCAD Capture would users like to see improved...
  • Replies 20
  • Subscribers 54
  • Views 19996
What areas of OrCAD Capture would users like to see improved?
dfernseb
dfernseb over 3 years ago
OrCAD Capture is a powerful schematic capture solution used by many commercial and educational institutions. Its longevity and functional flexibility has made it a staple to PCB, Packaging, and FPGA design flows. As we continue to enhance the core product based on our strategic initiatives I'd like to get feedback from the users of where you feel we could provide the most value to accelerate your productivity. Is it in technology areas like library development, data management, simulation, etc... or in modernization of presentation, usability, and ecosystem?
I look forward to the dialog! Slight smile
  • jgregoire
    jgregoire over 3 years ago +4
    Most of the Capture options have incredibly unhelpful names/descriptions. Some of them do unpredictable and catastrophic things. Symbol Editor is crusty and slow. Quality of life is horrible if you want…
  • RFinley
    RFinley over 3 years ago +3
    Engineers like to complain about CIS. I've used Orcad and occasional DxDesigner/Viewdraw since the late 80's so it takes a lot to bug me. Need a way to define the page sequences in intelligent PDF exports…
  • jgregoire
    jgregoire over 3 years ago in reply to RFinley +3
    This behavior drives me nuts. Our mechanical designers use C and D size by default, but the largest printer we have is 11x17. Good luck reading those dimensions... In ECAD land we stick to B (default…
  • mbmsv
    mbmsv over 3 years ago
    Hello!
    Is this request still active? Would you like to see a big list of suggestions/complaints or a single post per issue would be OK/preferable?
    /Mikhail
  • mbmsv
    IWashburn said:
    Same with placing net aliases - I do not want to have to restart the Place Alias tool every time just so I can change the name of the alias.
    Actually you don't need to restart the Place Alias each time. Right click and choose Edit Properties instead. Note that if your alias ends with a number the tool will automatically increment that number by 1. This, of course, should be an option but it is not.
  • IWashburn
    IWashburn over 3 years ago in reply to mbmsv
    Good in theory, but bad in practice. It takes two clicks to right-click and select Edit Properties. It takes one click to restart the tool. In both cases it is a pain to have to move my hand to the mouse and move the cursor around after using the keyboard to assign the alias name. It would be nice to be able to simply hit a key like "Tab" on the keyboard to edit the current alias attached to the cursor.
  • mbmsv
    mbmsv over 3 years ago in reply to IWashburn
    Apparently if you use the N shortcut for starting the tool that's exactly how it works!
  • IWashburn
    Ah, sure enough, that seems to work. I was thinking that was a custom shortcut I created, not a default. Glad that's in there, at least
