  2. Allegro X Capture CIS
  3. Custom Off-Page Connectors
  • State Verified Answer
  • Subscribers 51
  • Views 8200
SpaceBird
SpaceBird over 3 years ago
I would like to use some custom Off-Page connectors at my company. I have the symbol and have added the library to the place-> Off-Page Connector dialog. This all works fine.
I recently started using the CoolEditBox to speed up development time. However, placing an off-page with CoolEditBox only places the default Cadence symbols >> or <<. Is there a way to change the default symbols that CoolEditBox is using?
  • steve
    steve over 3 years ago +1 verified
    Not 100% certain but look at the installation directory for CoolEditBox for a library called EDAIS.olb. This contains the offpage connectors etc. You should be able to put your symbols in there and see…
  • rg13
    0 rg13 over 3 years ago
    CoolEditBox does not seem to be Cadence's proprietary. You may want to contact directly with manufacturer of CoolEditBox.
  • steve
    +1 steve over 3 years ago
    Not 100% certain but look at the installation directory for CoolEditBox for a library called EDAIS.olb. This contains the offpage connectors etc. You should be able to put your symbols in there and see if they are then used. Make a backup copy first (as I said - not 100% on this).
  • SpaceBird
    0 SpaceBird over 3 years ago in reply to steve
    That worked great thanks! It would be great if I could keep those in our central library, but that will definitely work for now.
