  2. Allegro X Capture CIS
  3. Unable to create bus in OrCAD capture in hierarchical design...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7819
Unable to create bus in OrCAD capture in hierarchical design unless schematic is root schematic
digital1
digital1 over 3 years ago
I am trying to create multiple schematic design but unable to create bus in any schematic unless it is the root schematic.
when i connect the pins of a component to a bus I get this dialog box
this normally comes up with the pin names populated
and when I make another schematic root the schematic with the bus on now shows this dialog box when i do the right click signals command on a net in the bus
has anyone found this problem
I am running OrCAD 22.1 hotfix 3
  • digital1
    0 digital1 over 3 years ago
    I found the answer I have to create a top level file and create a hierarchical block for the various schematics so I can create the buses.
    So it has to be top down design and not bottom up design
  • rg13
    0 rg13 over 3 years ago in reply to digital1
    I also found the same behavior through out 17.2, 17.4 and 22.1. Yes, you are correct, Its good to go with top down approach in this scenario.
