  2. Allegro X Capture CIS
  3. bring CIS components to OrCad capture, error ORCAP-2396
  • State Verified Answer
  • Subscribers 50
  • Views 8154
Yishai123
Yishai123 over 3 years ago
Can't import components from CIS Explorer to OrCad SCH capture. I have tried to Import the same component several times and get the same error.
Please see below the error message:
ERROR(ORCIS-6184): The selected component cannot be placed on the schematic. Refer to Session Log to resolve the error
ERROR(ORCAP-2396): The selected component, 'FID_0050', cannot be placed on the schematic as the schematic page is not active. Launch CIS Explorer from the schematic page, and try to place the component again. In case this problem persists, contact Cadence Customer Support with the steps resulting in the error.
Any help will be appreciated.
Thx,
Yishai,
  • AyushD
    AyushD over 3 years ago +2 verified
    Hello Yishai, As the error suggests you have not invoked CIS Explorer window from an active schematic page. Try below steps Open your design -> open a schematic page, click anywhere on the schematic…
  • AyushD
    +1 AyushD over 3 years ago
    Hello Yishai,
    Open your design -> open a schematic page, click anywhere on the schematic canvas and then invoke CIS explorer and try to place the component.
    • Vote Up +2 Vote Down
  • Yishai123
    0 Yishai123 over 3 years ago in reply to AyushD
    Hi Ayush,
    Thank you,
    Your suggestion above solves the problem. I have succeeded in importing the component through CSI.
    It's strange because I have opened only one page previously to the issue and routed some NETs through the SCH. In this case, the SCH page needs to be active, I'm right?
    If so, and if I'm right, it's strange that I got those errors.
    Thank you again,
    Yishai,
  • AyushD
    0 AyushD over 3 years ago in reply to Yishai123
    It might have happened that just before invoking CIS Explorer you might have clicked on any other branch in CIS Explorer and in that case this error came up
  • Yishai123
    Maybe you are right,
    Thank you for your assistance.
    Yishai,
