  2. Allegro X Capture CIS
  3. Design Sync Layout Folder
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7866
TpermanLuma
TpermanLuma over 2 years ago
I am trying to configure the design sync between my .DSN design in Allegro Design Entry CIS and layout in Allegro PCB Editor, to allow the Update Layout... functionality to be used
In the 'Design Sync Setup' menu, accessed from PCB-> Design Sync Setup you specify the Layout Folder. I have tried to set this to the allegro subfolder in my project directory, but it keeps reverting to allegro\allegro. In other words another subfolder inside the allegro folder and not the folder where the .BRD is stored. Is this configured from somewhere else?
  • AyushD
    AyushD over 2 years ago +1 suggested
    Go to PCB > New Layout and then enter allegro as PCB Layout folder and give Input Board file and Board as same and then select. Also try to rename capture.ini present at your home location <%HOME%>\cdssetup…
  • Neho Jey
    0 Neho Jey over 2 years ago
    Allegro uses environment variables to define paths. Ensure that the environment variables related to layout folders are set correctly. You can check this by going to File -> Export -> Design Sync and then navigating to the Paths tab.
    friday Night funkin
