  2. Allegro X Capture CIS
  3. Design Sync Layout Folder
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7860
TpermanLuma
TpermanLuma over 2 years ago
I am trying to configure the design sync between my .DSN design in Allegro Design Entry CIS and layout in Allegro PCB Editor, to allow the Update Layout... functionality to be used
In the 'Design Sync Setup' menu, accessed from PCB-> Design Sync Setup you specify the Layout Folder. I have tried to set this to the allegro subfolder in my project directory, but it keeps reverting to allegro\allegro. In other words another subfolder inside the allegro folder and not the folder where the .BRD is stored. Is this configured from somewhere else?
  • AyushD
    AyushD over 2 years ago +1 suggested
    Go to PCB > New Layout and then enter allegro as PCB Layout folder and give Input Board file and Board as same and then select. Also try to rename capture.ini present at your home location <%HOME%>\cdssetup…
  • AyushD
    0 AyushD over 2 years ago
    Also try to rename capture.ini present at your home location <%HOME%>\cdssetup\OrCAD_Capture\23.1.0\capture.ini
    See if that helps.
  • AyushD
    What is the tool version you are using ?
  • TpermanLuma
    0 TpermanLuma over 2 years ago in reply to AyushD
    I'm using 22.1-2022 S008 [1/15/2024] Windows SPB 64-bit Edition
  • TpermanLuma
    What do you suggest this is renamed to? Are you suggesting doing this so that the default configuration is used?
  • AyushD
    0 AyushD over 2 years ago in reply to TpermanLuma
    yes you can rename it to anything like capture_old.ini. Do it after closing the tool and after renaming launch Capture and a new ini file will get created with default configurations.
