  2. Allegro X Capture CIS
  3. OrCAD Tip of the week: Opening the DSN file directly from...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 10863
OrCAD Tip of the week: Opening the DSN file directly from the file explorer is leading to PCB editor window and not the capture schematic
RohitRohan
RohitRohan over 2 years ago
Opening the DSN file directly from the file explorer is leading to PCB editor window and not the capture schematic.
From the below image you can see the .DSN file having the icon of the PCB editor and when trying to open the .DSN file, the PCB editor opens instead of the Capture schematic. (Note below steps are for Window 10)
  • To resolve it, Right click on the .DSN file >> Properties >> Change >> More Apps >> Look for another app on this PC.
  • Go to install director (For example C Drive, where the Cadence software is installed) >> Cadence >> SPBxx.x (For Example SPB23.1)
  • Tools >> Bin >> Select Capture.
  • Apply >> OK.
  • Once done the icon for the .DSN file will be changed to Capture symbol (Below image for reference)
  • rg13
    rg13 over 2 years ago +1 suggested
    RohitRohan That's good piece of information. Exciting to see that it came from you. Moreover, articles on similar issues are present on Cadence online support portal which are as follows: Article …
  • rg13
    0 rg13 over 2 years ago
    Article (11265098) Title: Unable to open a Design Entry CIS design file (.dsn) by double-clicking it
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXhgEAE
    Article (20490458) Title: Icons of design and project files do not match with the version selected in Cadence Switch Release
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009bgzMEAQ
    You may want to refer these links.
