  2. Allegro X Capture CIS
  3. orcad capture breakout
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 5551
Liao hi
Liao hi over 2 years ago
The orcad capture always breakout when I use the command "make root".   it shows the message "ERROR(ORCAP-1356):memory exhausted, you can close and/ or release memory in other applications and retry Note that a cancel immediately exits the application"
  • Liao hi
    Liao hi over 2 years ago in reply to Akshay khosla +1 suggested
    I have found the reason. The breakout because of the "online DRC". you should turn off the "online DRC" in the desgin rules check if there are a lot of DRC error. The online DRC will autorun when i use…
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    Hi Liao,
    Please let us know the SPB tool version you are working on (like SPB22.1 or SPB23.1) also confirm if this is a design specific issue or reproducible on multiple designs.
  • Liao hi
    0 Liao hi over 2 years ago in reply to Akshay khosla
    Thanks! The SPB tool version is SPB17.4. and the patch (Hotfix_SPB17.40.035) has been installed.
  • Liao hi
    I have found the reason. The breakout because of the "online DRC". you should turn off the "online DRC" in the desgin rules check if there are a lot of DRC error. The online DRC will autorun when i use the make root. Hope this can help others.
