  2. Allegro X Capture CIS
  3. How to see the footprint preview in CIS Explorer?
  • Subscribers 53
  • Views 6207
yugandhar
yugandhar over 2 years ago
While working on a schematic, you might want to see the footprints of parts used in the design. For this, it is no longer required to open the .dra file in Allegro. You can see the footprint of the parts present in your database in the Footprint window of CIS Explorer, as shown below.
For this, go to the %HOME%\cdssetup\OrCAD_Capture\23.1.0\ location and open the Capture.ini file in any text editor.
You can specify the path of footprints under the [Allegro Footprints] section against Dir0, Dir1, and so on.
After this is done, you can see the footprint of parts from your database in CIS Explorer.
Yugandhar.
  • growthstarboard
    growthstarboard over 2 years ago
    Thanks you, yugandhar. I am looking for instructions to see the footprint preview. That's useful.
    geometry dash world
  • Jeet
    Jeet over 2 years ago in reply to growthstarboard
    Thanks good to know that the post was helpful !
  • Ulf K
    Ulf K over 2 years ago
    It can be worth mentioning, that when using 23.1 and mapping a STEP-file to a newly created footprint, the footprint preview feature in CIS is broken. This when using HF004. (I have not tested it using HF005). A work-around is when creating footprints and mapping them to use 22.1 until Cadence has issued a fix for this.
  • JB202506127449
    JB202506127449 over 1 year ago
     I am looking for instructions to see the footprint preview. so good!
