  2. Allegro X Capture CIS
  3. In Win11 24H2 OS, Allegro X Capture23.1 HF006 has issues...
  • State Verified Answer
  • Replies 30
  • Subscribers 60
  • Views 16573
In Win11 24H2 OS, Allegro X Capture23.1 HF006 has issues with zooming in and out
Zhifeng Jin
Zhifeng Jin over 2 years ago
everybody,
Recently, I found that there is an issue with the zoom display of Allegro X Capture23.1 (HF005,HF006) in the Win11 24H2 operating system.
When I use the I key to zoom in, it does not zoom in at the current mouse cursor position. In addition, the mouse cursor may appear outside the drawing area.
This issue also occurs when I use the right mouse button to select or press Ctrl+mouse scroll to zoom in.
My operating system version is: Windows 11 x64 24H2 26100.1301
Have you encountered this kind of problem?
  • bengelJF
    bengelJF over 1 year ago +2
    I can also report that I am having this issue. This is incredibly irritating since I'm zooming in and out of schematic pages constantly.
  • Zhifeng Jin
    Zhifeng Jin over 1 year ago in reply to taszymanski +2
    Four months ago, when I raised this issue, I had already discovered that unchecking the "Grid Preferences" option could temporarily solve the problem, but unfortunately, it wasn't until Microsoft fully…
  • Zhifeng Jin
    Zhifeng Jin over 1 year ago +2
    Some good news to share with everyone. Recently, I updated my OS Windows 11(24H2)to the latest beta version, and it seems that the zoom display issue no longer occurs. The OS version I have updated to…
  • rg13
    0 rg13 over 2 years ago
    @jinzhifeng I am getting it checked here at my end. I will try to test it one different machines. With windows 10, I have checked there is no issue with zoom in and out with ISR#6.
    ISR#5 and windows 11 combination has also been checked and there also, I haven't observed any issue. I will get it checked with ISR#6 now on windows 11.
    Do you have any machine with Windows 11 - 23H2 22631.3447 at which ISR#6 is installed?
  • Zhifeng Jin
    0 Zhifeng Jin over 2 years ago in reply to rg13
    Perhaps you can try the version on Windows 11 24H2 first. Because it seems that this issue does not exist in window 11 23H2.
  • Zhifeng Jin
    Have you encountered this issue on Windows 11 24H2 OS?Thinking
  • rg13
    0 rg13 over 2 years ago in reply to Zhifeng Jin
    Looking for machine at which 24H2 is installed. Else, will have to get it installed by IT and then will check.
  • Zhifeng Jin
    Thank you, I understand.
    I have found that from OrCAD17.4-2019-P001 to OrCAD23.1-S006, regardless of whether any hotfixes are installed, as long as they are in 24H2 OS, there will be this issue.
    Considering that 24H2 is expected to be released in the future, similar issues will be reported gradually. I think it is possible to generate a CCR and priority for this issue.
    Also, I found that this issue may be related to Grid Reference.
