  2. Allegro X Capture CIS
  3. In Win11 24H2 OS, Allegro X Capture23.1 HF006 has issues...
  • State Verified Answer
  • Replies 30
  • Subscribers 60
  • Views 16608
In Win11 24H2 OS, Allegro X Capture23.1 HF006 has issues with zooming in and out
Zhifeng Jin
Zhifeng Jin over 2 years ago
everybody,
Recently, I found that there is an issue with the zoom display of Allegro X Capture23.1 (HF005,HF006) in the Win11 24H2 operating system.
When I use the I key to zoom in, it does not zoom in at the current mouse cursor position. In addition, the mouse cursor may appear outside the drawing area.
This issue also occurs when I use the right mouse button to select or press Ctrl+mouse scroll to zoom in.
My operating system version is: Windows 11 x64 24H2 26100.1301
Have you encountered this kind of problem?
  • bengelJF
    bengelJF over 1 year ago +2
    I can also report that I am having this issue. This is incredibly irritating since I'm zooming in and out of schematic pages constantly.
  • Zhifeng Jin
    Zhifeng Jin over 1 year ago in reply to taszymanski +2
    Four months ago, when I raised this issue, I had already discovered that unchecking the "Grid Preferences" option could temporarily solve the problem, but unfortunately, it wasn't until Microsoft fully…
  • Zhifeng Jin
    Zhifeng Jin over 1 year ago +2
    Some good news to share with everyone. Recently, I updated my OS Windows 11(24H2)to the latest beta version, and it seems that the zoom display issue no longer occurs. The OS version I have updated to…
  • Maddin
    0 Maddin over 1 year ago in reply to Maddin
    The workaround to switch-off the "Grid References" does work for zooming on a page but does not work when coming from another window like CIS Explorer or Edit Properties. Coming back from such a window result in a different position as before on that page.
  • Zhifeng Jin
    +1 Zhifeng Jin over 1 year ago in reply to Maddin
    Cadence seems to have fixed this scaling issue in the latest ORCAD 24.1-003 hotfix. You can try to install the OrCAD 24.10.003 hotfix and provide feedback on whether the problem has been solved. Good luck!
  • FB202502193638
    0 FB202502193638 over 1 year ago
    Hi
    I had the same problem—my zoom was working until I noticed a weird behavior, even though I didn't change any settings.
    I updated the graphic card drivers to solve it, i remebered this happened with other 3D CADs( weird behavior/no menu or cursor)
    Allegro X 23.1 Capture CIS
    Windows 11 24H2
    Ryzen 5 Nvidia RTX3050TI
    -Fabrizio
  • Maddin
    0 Maddin over 1 year ago in reply to Zhifeng Jin
    The scaling issue problem has disappeared!
    I'm still on OrCAD 23.1 S006 - nothing changed here. But two other things have changed:
    a) The Win11 24H2 build is now 26100.3775
    b) Meanwhile I have installed the Allegro PCB Editor Viewer 24.1
    I don't know which of these changes solved the problem.
  • Zhifeng Jin
    Yes, the latest May update for Windows 24H2 has fixed this issue
