  2. Allegro X Capture CIS
  3. How to resolve error orcap-1655
  • State Verified Answer
  • Subscribers 50
  • Views 5315
FH20240823846
FH20240823846 over 2 years ago
Tell me please how to resolve this
  • Jeet
    Jeet over 2 years ago +1 verified
    ERROR ORCAP-1655 indicates that the underlying schematic of the hierarchical block is not present at that location. To resolve this error, you can try re-browsing to the correct Implementation Path of…
  • Jeet
    Jeet over 2 years ago in reply to FH20240823846 +1 verified
    Launch OrCAD Capture and Choose Options > Preferences > Miscellaneous > Enable Intertool Communication. Generate the netlist from the schematic design by Tools > Create Netlist and Import in the…
  • Jeet
    +1 Jeet over 2 years ago
    To resolve this error, you can try re-browsing to the correct Implementation Path of the H-Block in the main design.
    Hope this helps!
  • FH20240823846
    0 FH20240823846 over 2 years ago in reply to Jeet
    Let me give a try
  • FH20240823846
    0 FH20240823846 over 2 years ago in reply to FH20240823846
    Thi helped me Vishwajeet singh thankyou so much the implementation path was set to network design now i have changed it to locally it resolves my problem.
    How can i cross probe between schematic and layout?
  • Jeet
    +1 Jeet over 2 years ago in reply to FH20240823846
    Generate the netlist from the schematic design by Tools > Create Netlist and Import in the board file by File > Import > Logic/ Netlist and select Import Type as Design Entry CIS () and browse the Import Directory.
    Now select any component it will get highlighted in the other tool.
    You can see details about Cross-Probing between OrCAD Capture and Allegro PCB Editor in depth by following Rapid Adoption Kit.
    Article (20416281) Title: Cross-Probing between OrCAD Capture and Allegro PCB Editor
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • FH20240823846
    Vishwajeet keep it up enabling this option worked for me
