  2. Allegro X Capture CIS
  3. Capture vs PCB Editor: Pin number mismatch Error messag...
  • State Verified Answer
  • Replies 12
  • Subscribers 54
  • Views 14705
Capture vs PCB Editor: Pin number mismatch Error message
Ulf K
Ulf K over 2 years ago
Forum Members:
(Capture CIS / OrCAD Layout Prof.)  v. 23.1)
I have a design where the (Capture) Schematic contains two SOT-89 symbols.
Their pins are designated "1", "2", "3"; and "TAB". The corresponding footprint has pads named exactly the same: "1", "2", "3", and "TAB".
Creating the layout, editing it, adding or changing components in the schematic is successfully synchronized every time.
The layout editor opens, it "Pulls" the schematic and the changes are applied.
But: I constantly have two warnings in Capture that the number of pins does not match:
Warning Physical (WARNING OrCAP-2435) Number of pins in footprint "SOT-89" and instance "U3" does not match (Same message for the other, U4...)
Did some programmer never thought of the possibility that pins could be numbered with other characters than numbers?
Or does Capture and PCB-Editor have different opinions about "numbers" ?
  • Ulf K
    Ulf K over 2 years ago +1 verified
    It was discovered that two footprints with same name but different number of pins existed. They were in two different sub-folders. Both sub-folders were listed in the .PSM search path configuration.…
  • MM202410209619
    0 MM202410209619 over 2 years ago in reply to MM202410209619
    I forget to mention that there is one Troubleshooting on Cadence Online Support Portal regarding ORCAP-2435.
  • JS202408156358
    0 JS202408156358 over 1 year ago in reply to Jeet
    This is an old thread, but I ran into a similar issue. In my case, I had downloaded footprints from Samtec. I found that pins were numbered as "01", "02",... and I had to change the pin text in the footprint to 1, 2,.... and remove the 0 prefix from the single digit numbers.
