  2. Allegro X Capture CIS
  3. Capture vs PCB Editor: Pin number mismatch Error messag...
  • State Verified Answer
  • Replies 12
  • Subscribers 54
  • Views 14698
Capture vs PCB Editor: Pin number mismatch Error message
Ulf K
Ulf K over 2 years ago
Forum Members:
(Capture CIS / OrCAD Layout Prof.)  v. 23.1)
I have a design where the (Capture) Schematic contains two SOT-89 symbols.
Their pins are designated "1", "2", "3"; and "TAB". The corresponding footprint has pads named exactly the same: "1", "2", "3", and "TAB".
Creating the layout, editing it, adding or changing components in the schematic is successfully synchronized every time.
The layout editor opens, it "Pulls" the schematic and the changes are applied.
But: I constantly have two warnings in Capture that the number of pins does not match:
Warning Physical (WARNING OrCAP-2435) Number of pins in footprint "SOT-89" and instance "U3" does not match (Same message for the other, U4...)
Did some programmer never thought of the possibility that pins could be numbered with other characters than numbers?
Or does Capture and PCB-Editor have different opinions about "numbers" ?
  • Ulf K
    Ulf K over 2 years ago +1 verified
    It was discovered that two footprints with same name but different number of pins existed. They were in two different sub-folders. Both sub-folders were listed in the .PSM search path configuration.…
  • Ulf K
    0 Ulf K over 2 years ago in reply to Ulf K
    Responding to the suggestions below:
    - Part numbering is "Numeric".
    - There are no "Dangles"/No-Connects on/associated with either the schematic symbol, its properties, the instances of them in the schematic or on the corresponding footprint.
    - The design is not connected to the cloud or relies on any downloaded symbol/footprint. CIP is not used for it.
    (I submitted the problem to Cadence support yesterday as "Important" but not a "show stopper".)
  • Ulf K
    +1 Ulf K over 2 years ago
    When one of the SOT89 foot prints was renamed, the error message disappeared....
    (Lesson learned)
  • Jeet
    0 Jeet over 2 years ago in reply to Ulf K
    What was the Part Numbering for the component you have created in the library(.OLB) was it Numeric or Alphabetic?
    Also, I just noticed SOT89 named footprint is present at sample location (C:\Cadence\SPB_23.1\share\pcb\pcb_lib\symbols) it might be causing the issue.
  • Ulf K
    0 Ulf K over 2 years ago in reply to Jeet
    In the .OLB, the part is designated "5V_AP7381-50Y-13_SOT89" with the foot print property set to "SOT89".
    I have other components added to the CIS-database that has different namnes but with the same footprint. Never any mismatch in those cases.
    In this case, the instantiation was for the component w/o any additional data such as MFR, MFR P/N etc. Placed schematic symbol. Footprint propertye automatically defined.
    The Cadence supplied libraries are omitted. In past times for the .OLB, the power pins were hidden with global nets which was not acceptable.
    Foot prints found in the \shared directories did have the same pad sizes for solder pads as for the solder masks. In Europe (or at least where I live), no automatic swelling is done by the board manufacturers. All data has to be "correct" when submitted except for traces where a tight impedance has to be maintained. (These traces are specified with a unique width and are used together with "coupons" for impedance verification after processing.
  • MM202410209619
    0 MM202410209619 over 2 years ago in reply to Jeet
    I was having the same issue and by changing to Numeric it solved the issue the warning went away.
