  2. Allegro X Capture CIS
  3. Capture vs PCB Editor: Pin number mismatch Error messag...
  • State Verified Answer
  • Replies 12
  • Subscribers 54
  • Views 14697
Capture vs PCB Editor: Pin number mismatch Error message
Ulf K
Ulf K over 2 years ago
Forum Members:
(Capture CIS / OrCAD Layout Prof.)  v. 23.1)
I have a design where the (Capture) Schematic contains two SOT-89 symbols.
Their pins are designated "1", "2", "3"; and "TAB". The corresponding footprint has pads named exactly the same: "1", "2", "3", and "TAB".
Creating the layout, editing it, adding or changing components in the schematic is successfully synchronized every time.
The layout editor opens, it "Pulls" the schematic and the changes are applied.
But: I constantly have two warnings in Capture that the number of pins does not match:
Warning Physical (WARNING OrCAP-2435) Number of pins in footprint "SOT-89" and instance "U3" does not match (Same message for the other, U4...)
Did some programmer never thought of the possibility that pins could be numbered with other characters than numbers?
Or does Capture and PCB-Editor have different opinions about "numbers" ?
  • Ulf K
    Ulf K over 2 years ago +1 verified
    It was discovered that two footprints with same name but different number of pins existed. They were in two different sub-folders. Both sub-folders were listed in the .PSM search path configuration.…
  • Jeet
    0 Jeet over 2 years ago
    WARNING ORCAP-2435 is a physical DRC and it comes when the number of pins in the schematic symbol does not match with the number of pins in the footprint and  alphanumeric pin numbers are case sensitive, so it must be ensured that the pin number's casing should be same in the schematic symbol and the footprint.
    To resolve this physical DRC warning, perform the following steps:
    1. Double-click on the DRC warning in the Online DRC window in OrCAD Capture. This will take you to the part on the schematic and highlight it.
    2. Right-click and choose Edit Part. This will open Capture Symbol Editor (Part Editor).
    3. Right-click and choose Edit Pins or press Shift+H. This will open the Edit Pins dialog box.
    4. Now, compare this with the footprint by opening the footprint file in Allegro PCB Editor.
    5. Choose Display > Status to see the count of Connect pins and Mechanical pins in Allegro PCB Editor.
    6. Compare, the number of pins footprint and in the schematic symbol.
    Let me know how it goes for you after performing the steps.
  • Ulf K
    0 Ulf K over 2 years ago in reply to Jeet
    Hi Vishwajeet.
    Thanks for responding to my question.
    (23.1 HotFix 007 by the way)
    I followed your instructions to the letter but found no discrepancies in either the schematic symbol nor the footprint.
    No hidden pins or pins set as "Power". All = Passive.
    No mechanical pins in the footprint.
    All pin "numbers" are either numbers or capital letters.
    No leading or trailing whitespaces.
    No DRC's in the Status-canvas in the PCB Editor. DRC's are "Green". Back drills grayed out (no drill holes)
    I am on active support with cadence. I can submit a trouble report but I thought that the forum was the best way to start.
  • Jeet
    0 Jeet over 2 years ago in reply to Ulf K
    You can contact Cadence Customer Support as it may need data sharing to debug this issue.
    Also, Can you check what is the Part Numbering is it Alphabetic or Numeric in Edit Part Window?
  • steve
    0 steve over 2 years ago
    Check the part to make sure there are no properties such as NC that can be used for no connect pins. If there are, delete the property and try again.
  • digital1
    0 digital1 over 2 years ago in reply to Jeet
    If you have the CIP product there is a button on the top of the form that compares the symbol and footprint. If there is a mismatch it will list all the pins of the schematic symbol and the pcb footprint making it easy to see the error
    Hope that helps
