  2. Allegro X Capture CIS
  3. There is a way to Synchronize Up multiple hierarchical blocks...
  • State Verified Answer
  • Replies 12
  • Subscribers 50
  • Views 5221
There is a way to Synchronize Up multiple hierarchical blocks ?
Adam
Adam over 1 year ago
There is a way to Synchronize Up multiple hierarchical blocks ? I do not find any way to do that...
  • Jeet
    Jeet over 1 year ago in reply to Adam +2 verified
    I created a new schematic and made some changes to a block. After performing a Synchronize Up operation on a block, I then ran Synchronize Across, as a result, the updates were successfully reflected in…
  • Adam
    0 Adam over 1 year ago in reply to Jeet
    I just try on an other design, from someone else, same behavior.
    - I create a new schematics and new page
    - In this new page some H-ports and wires, H-Port defined as Power, Inputs, Outputs, H-ports can be bus
    - Creating H-Block in the TOP
    - Connect wires and buses
    - Copy the H-Block and paste in the TOP
    - Remove a H-Port in the created schematic
    - Come back to TOP, try to Synchronize Across, nothing Happen
    If I synchronize Up, the selected block update itself. Try again to synchronize across do nothing.
  • Adam
    No one have solution ? It's a bug ?
  • Jeet
    +1 Jeet over 1 year ago in reply to Adam
    I created a new schematic and made some changes to a block. After performing a Synchronize Up operation on a block, I then ran Synchronize Across, as a result, the updates were successfully reflected in another H-block.
     https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/109/TEST.DSN
    Can you give a try with this schematic design ?
    • Vote Up +2 Vote Down
  • Adam
    Strange, i test the file you sent and it's worked, i come back on my design and it's working well too.
    Thanks for support.
  • Jeet
    0 Jeet over 1 year ago in reply to Adam
    Glad it worked for you, Thanks for the feedback!
