  2. Allegro X Capture CIS
  3. There is a way to Synchronize Up multiple hierarchical blocks...
  • State Verified Answer
  • Replies 12
  • Subscribers 50
  • Views 5220
There is a way to Synchronize Up multiple hierarchical blocks ?
Adam
Adam over 1 year ago
There is a way to Synchronize Up multiple hierarchical blocks ? I do not find any way to do that...
  • Jeet
    Jeet over 1 year ago in reply to Adam +2 verified
    I created a new schematic and made some changes to a block. After performing a Synchronize Up operation on a block, I then ran Synchronize Across, as a result, the updates were successfully reflected in…
  • Jeet
    0 Jeet over 1 year ago
    To synchronize all H-blocks as per the latest changes made in the lower-level schematic, you can use the Synchronize Across command. Select H-block, right-click, and choose Synchronize Across option. This operation will reflect those changes and add the H-pins to all hierarchical blocks present in the schematic.
  • Adam
    0 Adam over 1 year ago in reply to Jeet
    Not working... I select the block, click right, Synchronize Across, nothing happen.
  • Jeet
    0 Jeet over 1 year ago in reply to Adam
    Are you able to perform Synchronize Up for one H-Block, which version of the tool you are using?
  • Adam
    Yes, Synchronize Up works well. I'm on 24.1-2024-S002 and I had the same behavior on S001
  • Jeet
    Which changes you are making in lower-level schematic , is it design specific issue or is reproducible with all designs ?
