  2. Allegro X Capture CIS
  3. There is a way to Synchronize Up multiple hierarchical blocks...
  • State Verified Answer
  • Replies 12
  • Subscribers 50
  • Views 5229
There is a way to Synchronize Up multiple hierarchical blocks ?
Adam
Adam over 1 year ago
There is a way to Synchronize Up multiple hierarchical blocks ? I do not find any way to do that...
  • Jeet
    Jeet over 1 year ago in reply to Adam +2 verified
    I created a new schematic and made some changes to a block. After performing a Synchronize Up operation on a block, I then ran Synchronize Across, as a result, the updates were successfully reflected in…
  • Adam
    0 Adam over 1 year ago in reply to Jeet
    Glad too,
    I just want to up that sometimes it's work well, sometime nothing happen with this function.
    It should be checked...
  • Jeet
    0 Jeet over 1 year ago in reply to Adam
    I tried this with another schematic design and it is working fine at my end, if I perform Synchronize Up operation on a block with lower schematic changes, and then perform Synchronize Across, it updates all the H-blocks pointing to same schematic.
    Are you facing any issue with a particular schematic design?
