  2. Allegro X Capture CIS
  3. Weird zoom in behavior in Capture CIS
  • Subscribers 50
  • Views 3370
PCBSHA
PCBSHA over 1 year ago
I am seeing very weird behavior in Capture CIS. When I double click on any part/symbol the property editor open and when I close this property editor (no matter if I change anything or not) some other area of the schematic is displayed. Also when keep control key pressed and scroll the mouse wheel it wont zoom in to the center of cursor.
  • Jeet
    0 Jeet over 1 year ago
    Which version of the Windows you are using and on which version of Capture you are seeing this behaviour?
  • PCBSHA
    0 PCBSHA over 1 year ago in reply to Jeet
    The one which is creating this problem, Win 11 Pro 24H2. I can handle the zoom in through mouse wheel but the other problem is really triggering me every time I open property editor.
  • Jeet
    0 Jeet over 1 year ago in reply to PCBSHA
    Can you try de-selecting Grid References from View > Grid References in OrCAD Capture?
    Also, are you referring Part Editor instead of Property Editor?
  • PCBSHA
    Thanks but I already did that. It will solve the zoom in issue as I mentioned earlier but not the other. I meant Property Editor, when double click on any part/net a new window will open.
  • Jeet
    If we double click on any component or any net from schematic page in OrCAD Capture it opens property editor, what issue you are facing in it, which new window is getting opened at your end?
