  2. Allegro X Capture CIS
  3. Dropping an Identical Component into an Existing Schematic...
  • State Verified Answer
  • Subscribers 50
  • Views 2038
Dropping an Identical Component into an Existing Schematic will not allow any Connection in version 23.10.006 - Very Different from all previous versions
cstocci52
cstocci52 over 1 year ago
Interesting "problem."  I delete any component in any schematic and attempt to cut-and-paste or drag and drop the exact same component into the same part of the circuit and I get a yellow triangle with an exclamation mark inside the yellow triangle.  The component will not connect to any of the wires.  The only way I can connect this component is to place it somewhere on the schematic page and manually connect wires to the component or vice-versa, then I can move the component into the same location in the schematic as the originally deleted part.
I think this is a "safety" issue, but not sure.  If it is a safety issue, can I disable that feature?
Second question: In version 17.4 and earlier, when connecting a wire onto a component or another wire to form a junction, I used to get and see a red "dot" indicating I was making a connection.  In version 23.10.006, that does NOT happen.  Now only after the connection is made and you release the mouse does the red junction graphic appear.  Feels weird and not the greatest feeling from a usage point of view.
Thanks!
  • steve
    0 steve over 1 year ago
    Sounds like you have toggles the "Drag selected component" icon to off. Its the icon that looks like a finger pointing upwards. If it's disabled it shows a red warning triangle. Toggle that and see if that helps.
  • cstocci52
    0 cstocci52 over 1 year ago in reply to steve
    Thanks, Steve.  Between you and Old Mouldy, I keep learning!  How about my second question?
  • steve
    0 steve over 1 year ago in reply to cstocci52
    The same option should also resolve that issue with the red dot.
  • cstocci52
    It did.  Thanks, Steve!!!!!!!!!
