  2. Allegro X Capture CIS
  3. Cross probing accumulating in Capture, instead of synchronizing...
  • Subscribers 51
  • Views 996
Cross probing accumulating in Capture, instead of synchronizing to what is currently selected
ersgfserg645
ersgfserg645 9 months ago
I'm on Allegro 25.1, I have a design where cross probing is acting weird, it is as if when I select parts in PCB Editor they are just added to the list in Capture, they are not removed from the list when I deselect them in PCB Editor, meaning that more and more parts are selected in Capture each time I deselect and select a new part in PCB Editor, when I really just wanted to step through the parts one by one.
Any ideas to why this might be so?
It works perfectly fine in a demo design.
  • TechnoBobby
    0 TechnoBobby 9 months ago
    Hi ersgfserg645 ,
    Since the issue appears to be specific to your design environment and may require a closer look at your project setup, we will reach out to you through another communication channel to investigate this further.
  • turrity
    0 turrity 6 days ago
    During fast cross-probing between OrCAD Capture and Allegro, when many components are selected in PCB and schematic objects are probed afterwards, XProbe Results keeps retaining the stale PCB selections even after placement completes. The only way to recover is to unselect components page by page in Capture, or reopen the project — the stale entries persist until each one is individually cleared from XProbe Results, causing erratic cross-probe navigation afterward.
