  2. Allegro X Capture CIS
  3. OrCAD X Capture 25.1 – PDF Export in Variant Mode Produces...
  • State Verified Answer
  • Replies 20
  • Subscribers 51
  • Views 8632
OrCAD X Capture 25.1 – PDF Export in Variant Mode Produces Extra Pages and Error Message
Kevcsc
Kevcsc 8 months ago
Hello everyone,
I’m currently using OrCAD X Capture 25.1, and I’m running into an issue when exporting a variant schematic to PDF. Every time I generate a PDF from a variant view, the output includes two extra pages, and one of those pages contains an error message that looks like below.
The actual error is captured as shown:
" ERROR: syntaxerror
OFFENDING COMMAND: ----nostringval----
STACK:
/JS
/JavaScript
/Subtype
-mark-
/Action
[0 0 0 ]
/Border
[0 1 0 ]
/Color
[748 61 604 1196 ]
/Rect
1/
SrcPg
-mark"
This only happens in variant as exporting the main schematic works normally with no extra pages or errors.
Has anyone seen this behavior before or know what might be causing it?
Thanks in advance!
  • Jeet
    Jeet 8 months ago +2
    This issue is reported in our Cadence Database via a CCR. Also, which hotfix of Version 25.1 you are using ? ( You can check hotfix by Help > About after invoking OrCAD Capture)
  • Krissn
    Krissn 6 months ago +2 verified
    The problem is one of the TCL scripts. Solution: Copy over capPdfUtil.tcl from working version of orcad/allegro (I used base version of 25.1 e.g. c:\Cadence\SPB_25.1\tools\capture\tclscripts\capPDFExport…
  • Kevcsc
    Kevcsc 7 months ago in reply to NG202603188945 +1
    Hi, same problem for me too. I was using 24.1 and it was working fine. I believe there is something wrong with 25.1 as soon as it releases. Probably have to wait for new update
  • AC202604093433
    0 AC202604093433 7 months ago in reply to NG202603188945
    Yes, it is orcad issue and we are trying to diagnose it. Orcad generates incorrect PostScript file that it feeds to Ghostscript. If we figure out what is wrong with the file, we can take corrective actions: tweak Ghostscript or file a well-founded bug report against Orcad.
    Orcad probably has an option to export *.ps files. Save this file and give it to me. Either post it somewhere on the net or email it to alex at coscript dot biz
    If Orcad cannot export *.ps, we will try to capture it in other ways.
  • NG202603188945
    0 NG202603188945 7 months ago in reply to AC202604093433
    Can you give me your email? Or how do I share. I can share the .ps file.
  • AC202604093433
    My email in the slightly obfuscated form is in my previous message.
  • Kevcsc
    0 Kevcsc 6 months ago in reply to Kevcsc
    I have updated to 25.01-S030. This issue still persists!
  • AC202604093433
    0 AC202604093433 6 months ago in reply to Kevcsc
    Can I have a sample PostScript file that has this problem? I know how to diagnose PostScript problems and hopefully fix them, but I don't run your software to reproduce the problem from scratch.
