  2. Allegro X Capture CIS
  3. OrCAD X Capture 25.1 – PDF Export in Variant Mode Produces...
  • State Verified Answer
  • Replies 20
  • Subscribers 51
  • Views 8647
OrCAD X Capture 25.1 – PDF Export in Variant Mode Produces Extra Pages and Error Message
Kevcsc
Kevcsc 8 months ago
Hello everyone,
I’m currently using OrCAD X Capture 25.1, and I’m running into an issue when exporting a variant schematic to PDF. Every time I generate a PDF from a variant view, the output includes two extra pages, and one of those pages contains an error message that looks like below.
The actual error is captured as shown:
" ERROR: syntaxerror
OFFENDING COMMAND: ----nostringval----
STACK:
/JS
/JavaScript
/Subtype
-mark-
/Action
[0 0 0 ]
/Border
[0 1 0 ]
/Color
[748 61 604 1196 ]
/Rect
1/
SrcPg
-mark"
This only happens in variant as exporting the main schematic works normally with no extra pages or errors.
Has anyone seen this behavior before or know what might be causing it?
Thanks in advance!
  • Jeet
    Jeet 8 months ago +2
    This issue is reported in our Cadence Database via a CCR. Also, which hotfix of Version 25.1 you are using ? ( You can check hotfix by Help > About after invoking OrCAD Capture)
  • Krissn
    Krissn 6 months ago +2 verified
    The problem is one of the TCL scripts. Solution: Copy over capPdfUtil.tcl from working version of orcad/allegro (I used base version of 25.1 e.g. c:\Cadence\SPB_25.1\tools\capture\tclscripts\capPDFExport…
  • Kevcsc
    Kevcsc 7 months ago in reply to NG202603188945 +1
    Hi, same problem for me too. I was using 24.1 and it was working fine. I believe there is something wrong with 25.1 as soon as it releases. Probably have to wait for new update
  • Krissn
    +1 Krissn 6 months ago
    Solution:
    Copy over capPdfUtil.tcl from working version of orcad/allegro (I used base version of 25.1 e.g. c:\Cadence\SPB_25.1\tools\capture\tclscripts\capPDFExport\tcl\) to your cadence and this should solve the problem.
    Shame on you cadence you can't provide fix for that quickly. Even latest 25.1 has no fix for that!
    • Vote Up +2 Vote Down
  • Krissn
    0 Krissn 6 months ago in reply to Krissn
    To be clear this is sketchy solution, but works
  • NG202603188945
    0 NG202603188945 6 months ago in reply to Krissn
    Yes it works.. why not Cadence guys can fixed with this?
  • Kevcsc
    0 Kevcsc 6 months ago in reply to Krissn
    This solution works for me too. Thank!
  • Krissn
    Good news.
    This issue is fixed in 24.1 S009
    Weirdly CCR notes does not mention that.
    I don't know if that help anyone but lines 619 620 capPDFUtil.tcl has been changed from:
    set lPropValue [DboTclHelper_sMakeCStringAppOwned $lVariantPropValue]
    DboTclHelper_sDeleteCString $lPropValue
    To
    set lPropValue [DboTclHelper_sMakeCString $lVariantPropValue 0]
