  2. Allegro X Capture CIS
  3. How to clear Error (OrCAD-1628)
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 921
kabalee
kabalee 5 months ago
HI Team,
I am using a 6-pin DC-DC converter in my OrCAD CIS design. Pins 4 and 6 are designated as 'Power' type pins for the voltage output (Vout). However, I am encountering an error whenever I connect a VCC or +15V rail to these pins
Error (Orcad-1628) Possible pin type conflict for Vout. How to resolve this issue.
  • TechnoBobby
    0 TechnoBobby 5 months ago
    Hi kabalee ,
    This error (ORCAP-1628: Possible pin type conflict) is reported by ERC when incompatible pin types are connected, based on the rules defined in the ERC Matrix (PCB > Design Rules Check.. > ERC Matrix). This behavior is controlled by how different pin types are allowed to connect in that matrix. I would suggest reviewing the ERC Matrix settings in your design and adjusting them as per your requirement.
    You can refer below article for more details:
    Article (20490986) Title: Getting "ERROR(ORCAP-1628): Possible pin type conflict" after running DRC
    URL: https://ask.cadence.com/ASK/article-viewer?id=a1O3w000009xwnFEAQ&pageName=article-viewer
    Hope this helps!
