  2. Allegro X Capture CIS
  3. Footprint viewer in Capture CIS 26.1 fails to display.
  • State Verified Answer
  • Subscribers 51
  • Views 339
Ulf K
Ulf K 15 days ago
Using W11 26H2 Professional.
Capture CIS 26.1 - Footprints not visible in either place part (CIS explorer) or place component (manually)
This sort of bug has been reported and corrected in a Hotfix for previous versions that had the same problem but the missing footprint view problem has popped up again.
When using CIS explorer and selecting a a component for which a footprint is defined, the "bar" lits up in green but only
the schematic symbol appears in the upper right corner. The layout symbol preview does not. This works in 25.1 but not in 26.1
Using the same database configuration (.DBC) file.
I have 25.1 and 26.1 installed on my computer.
All DIR0, DIR1 etc. settings are identical.
Settings in capture.ini is the same according to below:
  community.cadence.com/.../orcad-tip-of-the-week-footprint-viewer-in-orcad-capture
Are there any new added configuration settings that needs to be configured?
  • oldmouldy
    oldmouldy 15 days ago +1 verified
    This does work fine if the Symbol files, DRA, ?SM and PAD, are up to date. The installation of my colleague is working with files processed with DB Doctor 24.1, my installation is working with files processed…
  • oldmouldy
    +1 oldmouldy 15 days ago
    This does work fine if the Symbol files, DRA, ?SM and PAD, are up to date. The installation of my colleague is working with files processed with DB Doctor 24.1, my installation is working with files processed with DB Doctor 26.1. Both CIS Explorer and Show Footprint are correct.
  • Ulf K
    0 Ulf K 15 days ago in reply to oldmouldy
    Thanks - If there was only a way to make dBDoctor_ui.exe do its work in a "quiet" mode. For each file, dBDoctor_ui opens a command window, that starts with @echo off, does what it is supposed to do and then closes that window. IMHO, maybe Cadence should add a check box "Use Quiet mode and display a % iprogress indicator only  [x]
