  3. information regarding Skill coding
  • Views 15476
Prasanna
Prasanna over 18 years ago
hi all,
 I am new  to skill coding. I have no idea about this. Can anybody tell what is skill coding. what is the purpose of using this. and how to implement in design?
  • skillUser
    skillUser over 18 years ago
     Hi Prasanna,
    SKILL is Cadence's proprietary coding language that is based on LISP. It is built into our PCB and IC tools, for example, Allegro, Concept and Virtuoso. The core language is the same between IC and PCB, though the tool-specific interfaces are different. SKILL provides a way of customizing the tool and automating various tasks. For example, you can modify or add to the tool menus, you can call the procedural commands that you would normally trigger from the user interface, and so on.
    I work with the Custom IC tools, so I do not know the best place to point you to, but I would expect that the documentation would be a great place to start.
    Lawrence.
  • pcbgeorge
    pcbgeorge over 18 years ago
    Look in $CDS_ROOT\doc for folders with "sk" in them.  Examples are:
    algroskill          Allegro Skill Extensions
    conceptsk           Concept Skill Extensions
    sklangref           Skill Language Reference
    sklanguser          Skill Language User Guide
    sklanguserKPNS      Skill Known Problems and solutions
    There are usually both PDF and Web versions of the documentation in each directory.  I would start with the user guide.
    Good luck :)
