  3. Autopopulate list box with list of files in directory
  • Views 15217
terrylau
terrylau over 18 years ago
I have a directory folder with a list of files in it. I want to autopopulate a listbox with the names of all these files with the extensions (minus the directory).
  1. Currently by using axlDMFileBrowse, I'm only able to select the one file at a time in the directory and then only populate the listbox one by one. This will be tedious if there's a huge list of files. Is there anyway to automatically search thru the whole folder and input the names of all the files into the listbox?
  2. Another problem is when I save the files into the list box, it comes out with the full extension including the directory whereas I only want the file name with the extension only. I know that using axlDMFileParts will return a list with list (directory file fileWext ext). How do I extract only the fileWext part?
Appreciate any of ur inputs again. Thanks in advance
  • DE202408202727
    DE202408202727 over 18 years ago
    1. Use getDirFiles returns a list of the files in the named diectory.
    2. Use caddr to get the third element of a list
    Cheersa, Dave
  • terrylau
    Thanks so much Dave... exactly what I needed :)
  • redwire
    redwire over 18 years ago
     http://sourcelink.cadence.com/docs/files/SKILL/Allegro_SKILL_Code/replay.il
    is an excellent template for learning how to do what you're looking for.  It searches files across multiple paths and populates a list box.
