  3. Can we read an image file(*.bmp)
  • Replies 14
  • Subscribers 166
  • Views 23151
ELEKVN
ELEKVN over 17 years ago
 i want to read in an image file(*.bmp) and inport it to allegro,but i
found no built-in functions can do this(open a port in binary mode and
read file bit by bit),
i also need to write some information in binary mode.
Elek
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Elek,
    I have written code to do this. See /forums/T/10154.aspx
    Cheers, Dave
  • ELEKVN
     It is great,you are a good man.
    Thank you very much
    Elek
  • DE202408202727
    You're welcome.
  • MAAC
    MAAC over 17 years ago
    Hello Dave,
    I`m new to skill.. i am not able to locate any ".ilint" file in the env folder..should i setup anything to retreive this..where should i save all the skill code so that i can give the skill>command in the PCB Editor to perform any action.
    Thnx.
  • DE202408202727
    You will need to create the allegro.ilinit file using a text editor. This should go in your [ALLEGRO_SITE]\pcb\skill folder.
    ie. c:\myAllegroSite\pcb\skill where your ALLEGRO_SITE Windows environment variable is set to c:\myAllegroSite.
    I don't recommend putting it in C:\Cadence\SPB_xx.x\tools\pcb\skill because you will lose that when you update your Allegro version.
    There are several clever features available to you in an ilinit file but you can just add the line:
    load("logoMaker_public.il")
    Cheers, Dave
