  3. Can we read an image file(*.bmp)
  • Replies 14
  • Subscribers 166
  • Views 23155
ELEKVN
ELEKVN over 17 years ago
 i want to read in an image file(*.bmp) and inport it to allegro,but i
found no built-in functions can do this(open a port in binary mode and
read file bit by bit),
i also need to write some information in binary mode.
Elek
  • MAAC
    MAAC over 17 years ago
    Hi Dave,
     Thnx for the reply..
    I tried the steps which u mentioned n copied the logoMaker_public.il file inside the pcb\skill folder(defined under Allegro_Site). Then i added  load("logoMaker_public.il")   inside the allegro.ilinit file, but i am facing the following error
    Skill > logomaker
    E- *Error* toplevel: undefined variable - logomaker
    nil
    n this is the 1st time i`m working with skill....Should i set any other path...
    Thnx....
  • DE202408202727
    DE202408202727 over 17 years ago
    Nearly there...
    You should type logomaker in the command console - not the Skill console.
    Cheers, Dave
  • MAAC
    Dave,
    Still i`m facing the same issue... i think i making some mistake in providing the path.....
    Command > logomaker
    E- Command not found: logomaker
    Command >
    I have tried with other skill also which are present in sourcelink.. The following is my .ilinit file
    load("add_symbol.il")
    load("checkWidth.il")
    I have this .ilinit file inside Skill folder where the above .il files are copied.
     Can you corrent me...
    Thnx
  • DE202408202727
    What is your ALLEGRO_SITE variable set to?
  • MAAC
    Allegro Site=d:\Allegrosite..
     Inside this folder i have pcb\skill where i have created the allegro .ilinit file and i have copied all the .il file(i.e. inside the skill folder)
    Thnx..
