  3. Can we read an image file(*.bmp)
  • Replies 14
  • Subscribers 166
  • Views 23158
ELEKVN
ELEKVN over 17 years ago
 i want to read in an image file(*.bmp) and inport it to allegro,but i
found no built-in functions can do this(open a port in binary mode and
read file bit by bit),
i also need to write some information in binary mode.
Elek
  • DE202408202727
    DE202408202727 over 17 years ago
    The variable should be ALLEGRO_SITE
    Cheers, Dave
  • MAAC
    MAAC over 17 years ago
    It is already set to ALLEGRO_SITE  d:\Allegrosite... n i`m able to see the same thru set of PCB Editor
    Thnx..
  • DE202408202727
    Ok. I think you need to get your local Cadence AE to take a look at your setup.
    Cheers, Dave
  • baimage
    baimage over 12 years ago
     here are some sample codes i'd like to share with you on how to read bmp image file, besides bmp image formats, it supports reading and viewing other image formats as well. these codes save me a lot of time finding a good solution.
